Security Advistory BPA reporting system is DAAS when it is Self Hosted/StaaS
Solved1.14K views26th June 202510.4 Installer BPA HTTPS SecurityAdvisoryBPA
HJC Dataminer Admin32 25th February 2025 0 Comments
I have installed a new self-hosted dataminer system using the 10.4 installer, and configured with STaaS. .
While working on HTTPS configuration, I decided to run the Security Advisory BPA and it reports that the instance is a DaaS instance, and presumably, doesn’t go any further in the BPA:
The BPA is 1.0.0.0 dated 9/3/2025.
How can I be sure the full SecurityAdvisoryBPA will run on a self-hosted system installed using the new 10.4 installer?
Seppe Dejonckheere [SLC] [DevOps Enabler]2.98K Posted 26th February 2025 0 Comments
You encountered a known issue that occurs because DataMiner Agents installed by the 10.4 installer and DaaS agents are licensed somewhat similarly. An updated BPA with improved DaaS detection is available from 10.4.0 CU 11, 10.5.0 and 10.5.2 onwards, so I would recommend to upgrade to the latest available version of the track you are following.
If it would not be possible for you to upgrade, feel free to reach out to me (seppe.dejonckheere@skyline.be). I can provide you with the updated BPA and guide you through the steps to replace it.
Kind regards,
