Saved filters option not visible for some users
Solved2.72K views12th July 2023Alarm Console Saved filters
Jan-Terje Larsen96 16th November 2022 0 Comments
One of our users are not able to select "Saved filters" in the filter-dropdown when creating a new tab in the alarm console.
In the below screenshot I would expect an option "Saved filters" after "View impact"
This is what I see with my user logged on:
Is there any rights-settings that enable/disable this feature?
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 16th November 2022 3 Comments
Hi Jan-Terje,
I ran some quick tests, and it seems that if the filter was created by a user from a different user group and the user doesn't have the right to "view users from other groups", then the user will not get access to those filters.
Would you be able to toggle this setting (temporarily) for the user in question to see if that is the cause of the observed behavior?
Jan-Terje Larsen commented 16th November 2022
Hi Ive,
Thanks, I’ll give this a shot tomorrow
Jan-Terje Larsen commented 17th November 2022
The user confirms he can now see the Saved Filters
Ive Herreman [SLC] [DevOps Enabler] commented 17th November 2022
Perfect, thanks for letting us know.
