Running query to cassandra cluster similar than query executor
Solved1.79K views27th August 2024cassandra cluster Cassandra schema
Edson Alfaro [SLC] [DevOps Advocate]1.76K 5th June 2024 0 Comments
Hi all!
In a DMS with local Cassandra, a user used to run some queries from System Center like following:
After the migration to Cassandra Cluster (twice), there is one cluster with old data, not connected to Dataminer anymore and they are looking to recover some information using DevCenter.
When having local Cassandra and executing from DevCenter, keyspace was SLDMADB and the query was over data table:
Now, if we would like to query the old Cassandra cluster, which would be the keyspace similar to SLDMADB in schema like following?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th August 2024
Michiel Saelen [SLC] [DevOps Advocate]6.50K Posted 6th June 2024 3 Comments
In the old data structure, all trend data (RT, short, medium and long) were in one table. This was the data table. As RT can generate much more load/size on disk than others, you typically want this to have a much lower TTL compared to others. With all the different TTLs on data in one table, it was almost impossible to compact out the data with Cassandra efficiently. For this reason, the data table has been split based on the TTL (rt, short, medium, long).
From the original command, you are using w=60 => hourly records, this would result in the medium trending. You will need to retrieve the data from the [prefix]_trend_data_medium keyspace (which holds only one table).
Michiel Saelen [SLC] [DevOps Advocate] commented 6th June 2024
Note: It is not advised to query the DataMiner DB directly. Mainly because this is not intended to be used as an API and could change over different DM versions. Offload DBs or using the export to CSV option on your trend graphs would be a better option.
Edson Alfaro [SLC] [DevOps Advocate] commented 6th June 2024
Thanks Michiel, the queries are intended to be done in a Cassandra cluster that was decommissioned as it was over an unsupported Linux version and it’s no longer connected to the DMS, but it is holding a lot of trending data that the user wants to retrieve.
Christhiam Aaron Calatayud Franco commented 7th June 2024
Thank you Edson and Michiel,
I appreciate your comments regarding this topic.
I’d like to mention that, starting with the following base:
select * from zm2_cc_trend_data_medium.trend_data_medium
The syntax of the previous query was restructured to be compatible with the current structure on our CC, obtaining consistent results like this example:
select t,cv,cvl,cvh from zm2_cc_trend_data_medium.trend_data_medium where d=26418 and e=1291 and p=13228 and t>=’2024-04-30 23:00:00′ and t<='2024-05-31 23:00:00' ALLOW FILTERING;
t,cv,cvl,cvh,
2024-05-23 23:00:00,4533.41404047111,4229.480752,4995.519152,
2024-05-24 00:00:00,4199.52532088,3898.3644,4496.846656,
2024-05-24 01:00:00,3557.73504328667,2951.748216,4144.76016,
2024-05-24 02:00:00,3304.68334798667,2903.526632,3719.418992,
2024-05-24 03:00:00,3341.20302634,2618.713368,4060.133904,
2024-05-24 04:00:00,2326.80122630444,1871.857568,2766.162456,
2024-05-24 05:00:00,1987.99808151556,1694.46596,2480.91928,
2024-05-24 06:00:00,2167.37017932,1693.616096,2626.697976,
2024-05-24 07:00:00,2339.71141571556,2037.432944,3304.422168,
2024-05-24 08:00:00,2712.41159888889,2128.459328,3869.928272,
2024-05-24 09:00:00,3344.00844494444,2893.10492,3869.928272,
2024-05-24 10:00:00,2927.11627609111,2404.38756,3496.135048,
2024-05-24 11:00:00,2802.24351449333,2483.579312,3104.251064,
2024-05-24 12:00:00,3406.68724741778,2842.99852,4250.431016,
Unfortunately, it is no longer possible to extract the information from the OLD CC due to interruptions and incomplete information.
Despite the foregoing, I believe we have made progress in obtaining more information about the CC clusters through query execution, which we have been doing with an export of the trend via UI, which has become an ongoing task when there are more than 25 queries per CC.
Regards
