RTE: Thread Problem in SLProtocol.exe
Solved2.70K views22nd June 2024adl2099 DMA RTE runtime error SLProtocol
Alberto De Luca [DevOps Enabler]5.75K 26th February 2024 0 Comments
When in presence of errors on SLProtocol.exe, DataMiner promptly flags these to admins & users:
what's the best type of capture // memory dump that can help in troubleshooting the root cause behind these hanging calls? Is it worth setting up some automation / correlation so that the related data collected automatically every time this type of RTE is listed in alarm console?
Thanks
Alberto De Luca [DevOps Enabler] Selected answer as best 22nd June 2024
Jon Corral [SLC] [DevOps Member]464 Posted 27th February 2024 0 Comments
Hi Alberto,
I am facing a similar issue for one of my customers. In my case, I found out the issue to be a driver problem. The way I found out was by executing Pending Calls via the SLNetClientTest tool.
If you grab the elementID from the Edit page of the element presenting the RTE, and you run the Pending Calls on the DMA hosting that element, you will probably be able to find which group or QAction is causing the protocol to get stuck.
With this information, you can later have a look at the driver and see what information is being retrieved by that group, and use this to guide a driver investigation afterwards.
You can find more related information and relevant troubleshooting steps in the following page
https://docs.dataminer.services/develop/devguide/Connector/Troubleshooting/Investigating_a_protocol_thread_RTE.html
Kind regards
Jon Corral [SLC] [DevOps Member] Edited answer 27th February 2024
