Requirements for installing Cube outside Dataminer servers
Solved1.23K views19th July 2023Cube installation requirements
Martin Sladek89 28th June 2023 0 Comments
Hello,
in our company we would like to use Cube on company laptops. Given all connectivity is in place, is there any other requirements to run Cube on laptops? According to this page, should some licences also be installed on a given laptop?
DataMiner Client Requirements
Thanks a lot.
M.
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 28th June 2023 0 Comments
Hi Martin,
No additional requirements are needed.
You can just launch the cube launcher and point it toward the hostname or IP of your dataminer server.
The Cube client doesn't require any separate license.
