Representing max values as interprete exceptions
Solved3.32K views19th July 2023exception interprete
Craig Dann 10th February 2021 0 Comments
I would like to disable a double parameter under certain circumstances. I would like to do this by setting the value to be the maximum allowed value for a double (all other values are valid values). Could you please let me know how to represent this in the XML file? i.e. what do I put in the xxx below? Thanks
<Interprete>
<Type>double</Type>
<RawType>double</RawType>
<LengthType>fixed</LengthType>
<Length>8</Length>
<Exceptions>
<Exception id="1" value="xxx">
<Display state="disabled">NOT INITIALIZED</Display>
<Value>xxx</Value>
</Exception>
</Exceptions>
</Interprete>
Jarno Lernou [SLC] [DevOps Enabler]6.09K Posted 10th February 2021 1 Comment
Hi Craig, a similar question was already asked. Does the answer serve what you need?
Edit
The other question was with RawType:numeric text, whereas here it's double. The maximum value will probably the same, as you specified 8 bytes as the length.
Craig Dann Posted new comment 10th February 2021
Craig Dann commented 10th February 2021
Thanks Jarno. It’s related, but I was wondering how to represent the value in the XML file. Thanks
