Replicated elements keep going in time-out
Solved3.13K views18th August 2020replication timeout
Reinout Daels [SLC] [DevOps Member]787 17th August 2020 0 Comments
I have replicated a couple of elements from one DMA on another DMA. The replicated elements have been running fine for a couple of months. Recently though, all the replicated elements have gone into time-out, while the original elements on the first DMA are still running fine. I guessed it had to do with changing my Windows password, since I used my personal domain account as credentials for the replication. I then updated the replication credentials on the replicated element settings to a local DataMiner user on the first DMA, in order to avoid this problem in the future, but still the elements keep going into time-out. Strangely, all parameter values on the replicated elements keep being correctly updated with the values from the original elements, but the replicated elements are nonetheless being flagged as in time-out. What could be the cause of this time-out?
Reinout Daels [SLC] [DevOps Member] Selected answer as best 18th August 2020
Jan Vanhove [SLC] [DevOps Member]1.23K Posted 18th August 2020 1 Comment
I confirm this is a genuine issue which we’ll fix. A replicated element does not leave its timeout state when you re-enter the password on the replicated element when it is in timeout (e.g. when credentials changed on the source DMA).
João Santos [SLC] Posted new comment 21st August 2020
João Santos [SLC] commented 21st August 2020
Jan, would it be possible to let us know also on this thread under which DataMiner version we’ll have the fix?
Miguel Obregon [SLC] [DevOps Catalyst]23.68K Posted 17th August 2020 1 Comment
Hi Reinout,
Although you mentioned that the parameters are updated, just to double check, can you try the following:
  • Can you check (using Stream Viewer) if you see the following message: Checking connection …
    Connecting Succeeded
  • Have you tried restarting the replicated element?
  • If you re-create the replicated element, do you have the same issue?
Reinout Daels [SLC] [DevOps Member] Posted new comment 17th August 2020
Reinout Daels [SLC] [DevOps Member] commented 17th August 2020
Hi Miguel,
Thanks for your reply. The Stream Viewer says ‘Connecting Succeeded’ for the replicated elements and restarting them does not clear the time-out flag. The only thing that works is just re-creating the replicated elements.
