Relationship between IDX and Interface Description
Solved3.46K views11th July 2023drivers
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate]945 5th November 2020 1 Comment
Hi
I use Arista drivers ver,2.0.7.6.
Changing the interface description changes “IfTable IDX” in Dataminer, which is inconvenient.
Is there a version that is not affected by Interface Description?
Postscript.
The index key exists, but it seems to be IDX that is referenced in Visio.
Every time you replace a device, description changes
When the Description changes, IDX changes.
It’s inconvenient because when IDX changes, Visio has to be modified as well.
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] commented 6th November 2020
Thank you all for your support.
I’ve postscript.
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 5th November 2020 0 Comments
Hi Yuki,
We normally use a numeric index for every row in a table, you can identify it because it is marked with a yellow icon.
Then we have what we call Display Key (little gray icon) which is the value you see in the alarms or trending records as the name of the interface.
If you make a change that affects the display key, like changing the interface description, as the main index is not changing, the indexing of the row data, alarms and trending won’t be affected.
Note that the index column could be hidden so you can make right-click over the name on any column to display the menu and select which columns would be visible.
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 5th November 2020 0 Comments
Hi Yuki,
Please could you elaborate a bit more your question? When you mention “Iftable IDX”, are you referring to the Detailed Interface Info Main table?
What specific column do you see updated (in the element) when you update the interface description in the device?
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 5th November 2020
