Refresh of Detailed Interface Info Tables in Cisco ASR Manager driver
Solved1.49K views7th July 2023Cisco asr manager
6
Jan-Terje Larsen156 15th March 2023 0 Comments
We have been missing a sub-interface on a Cisco ASR element in Dataminer for days. After clicking the Refresh button on the "Measurement Configuration Table" page the sub-interface appeared. Last line in the screenshot
I was expecting this to be automatically updated? Both when new interfaces appear, and when interfaces are being deleted on the node.
We are using version 1.0.1.31 of the "Cisco ASR Manager" driver.
Michiel Oda [SLC] [DevOps Advocate]3.84K Posted 15th March 2023 0 Comments
Hi Jan-Terje
I'm not familiar with the Cisco ASR Manager but when looking at the Driver Help which is visible on the catalog, it mentions that on the General page there are options to toggle the polling of certain tables. Could you check if that table is available there and if polling is enabled.
Michiel Oda [SLC] [DevOps Advocate] Answered question 15th March 2023
