Range Slider Control: Sets while dragging the slider
Solved1.86K views15th September 2023Visual Overview
Miguel Obregon [SLC] [DevOps Catalyst]23.65K 15th September 2023 0 Comments
Hi Dojo team,
We have a question about this feature Creating a range slider control. We noticed that the parameter set is performed only after we stop dragging the slider. Do you know if there is a way to set the parameter linked to the shape while dragging the slider?
Thanks!
Miguel Obregon [SLC] [DevOps Catalyst] Selected answer as best 15th September 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 15th September 2023 1 Comment
Hi Miguel,
At present, this isn't achievable. If it were to become supported in the future, it would likely require sampling as well, as moving the mouse can potentially trigger numerous events.
Miguel Obregon [SLC] [DevOps Catalyst] commented 15th September 2023
Hi Sebastiaan,
Thanks for the quick answer!
