Qaction triggers on write parameter, and trigger on change of parameter, order of execution?
Solved1.70K views18th July 2023
filiep geeraert [SLC]83 10th November 2021 0 Comments
I encountered a case where on a write parameter, there was :
  • write parameter 258 --> Qaction 250 with trigger on write parameter 258
  • trigger on change of parameter 258 --> action --> execute next group 50
Is the order fixed?
Meaning, will the QAction always be launched first, or will the group always be launched first, or is there no specific order in this case, and will it vary from time to time?
Jens Vandewalle [SLC] [DevOps Advocate]9.95K Posted 10th November 2021 1 Comment
Hi Filiep,
It depends on the group type:
  • In case of type poll (action/trigger) the QAction will be executed first
  • In case of type action/trigger I don't think that there is a fixed order
filiep geeraert [SLC] Posted new comment 15th November 2021
filiep geeraert [SLC] commented 15th November 2021
It seems your answer differs from the one given by Joey Vandewalle.
I wonder who is right.
