Prometheus driver – how does it work?
Solved3.44K views5th June 2020Prometheus
8
Thomas Gunkel [SLC] [DevOps Enabler]1.24K 4th June 2020 0 Comments
I need info on the DataMiner Prometheus driver.
Is there a collector driver available? Can I have more than one collector installed?
Does the driver create DVEs or additional elements per Prometheus job or instance?
Thomas Gunkel [SLC] [DevOps Enabler] Selected answer as best 5th June 2020
Laurens Moutton [SLC] [DevOps Enabler]9.93K Posted 5th June 2020 2 Comments
Hi Thomas,
The collector driver is currently under functional review waiting to be released. There can be more than one collector element installed. At this moment it does not support DVEs yet, base component elements need to be created. A base component element can contain results of multiple queries depending on the value of a metric label, meaning if that multiple jobs or instances could end up in the same element if needed.
Information is available on the driver help pages:
For the collector see: https://catalog.dataminer.services/result/driver/6717
For the base component see:
https://catalog.dataminer.services/result/driver/6722
Ben Borra [SLC] Posted new comment 20th January 2021
Chris Piepenbring commented 19th January 2021
Has this collector driver been released? The two links above lead to more or less blank pages.
Ben Borra [SLC] commented 20th January 2021
Hi Chris
Thank you for letting us know of the issue.
It seems that something went wrong on our end causing your account to not have the necessary permissions.
I’ve updated your permissions and you should now be able to see the catalog pages.
Kind regards
Ben
