Progress bar on Interactive Automation Script?
Solved2.10K views6th July 2023IAS interactive automation script progress bar
10
Guilherme Gaspar [SLC] [DevOps Member]549 5th April 2023 3 Comments
Is it possible to have a Progress Bar in an Interactive Automation Script?
Ben Vandenberghe [SLC] [DevOps Advocate] commented 5th April 2023
Great thought! Would you be referring to progress of the entire interactive part of the workflow (e.g. step 2 / 7) or are you referring to showing a progress bar at one point in the workflow to show progress of an underlying activity that the user has to wait for at that point in the interactive engagement?
Miguel Obregon [SLC] [DevOps Catalyst] commented 5th April 2023
Another possible option could be the proposal in this question:
https://community.dataminer.services/question/interactive-automation-toolkit-how-to-show-informative-loading-screen/
Guilherme Gaspar [SLC] [DevOps Member] commented 5th April 2023
Your second point. The goal is to give continuous feedback to the user on a (probably) time-consuming activity they just triggered, where they would need to wait for it to be finished to proceed with their work or repeat a similar action. Yes, it can be done with the “step X of Y” method as a workaround, but nothing beats a progress bar, in my opinion.
João Severino [SLC] [DevOps Enabler]14.71K Posted 5th April 2023 1 Comment
Hi Guilherme,
I do not think a progress bar is possible as a “bar” since I do not see it in the available options.
But it should be possible something similar to a percentage value or show a changing value like step 5 of 9.
You could use a regular StaticText which together with the ShowProgress method would allow you to redraw what is on screen without the need to have the user press a button or change something for the code to regain control.
Robin Becker [DevOps Member] commented 6th April 2023
Back to ASCII art style progress bars!
