Process Automation queue cleanup
Solved2.03K views23rd October 2023process automation
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 19th October 2023 1 Comment
The process automation looks like it’s stuck.  I would like to clean up the queue to try with a single token if it works
How do I clean up the queue, and is there a way to restart process automation?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd October 2023
Jeroen Geldhof [SLC] [DevOps Enabler] commented 19th October 2023
I just figured out the problem.
No need to clear up the queue anymore.
The problem was in one of the actions
André Rodrigues [SLC] [DevOps Advocate]884 Posted 20th October 2023 0 Comments
Hi Jeroen,
Glad you found the solution. To clear the queue elements or restart the process, the best way is to complete the associated booking and create a new one. The existing booking, when finished, will complete the associated tokens that are in progress.
