problems saving uploaded system logo
Solved1.83K views18th July 2023logo
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 28th October 2021 0 Comments
After uploading a logo (in png or jpg, small or large) I'm having problems saving the setting.
Each time I open System Center>Agents, the logo has dissapeared.
What could prevent that setting from not being saved?
Is there a workaround to set the logo?
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.48K Posted 28th October 2021 0 Comments
This is possibly related to RN30581. A work around is to place file manually here: C:\Skyline DataMiner\WebPages\CustomerLogo.jpg  then restart cube.
Wale Oguntoyinbo [SLC] [DevOps Advocate] Answered question 28th October 2021
