Problems accessing Localhost
Solved2.18K views14th July 2023
Hugo Andrade [SLC] [DevOps Member]213 20th June 2022 5 Comments
Hi everyone,
When I try to access my localhost I get this error. Does anyone have an idea of what may be causing it or how to solve it?
Thanks.
Gellynck Jens [SLC] commented 20th June 2022
Hi Hugo, is HTTPS enabled on your DataMiner? You can verify this by checking if the MaintenanceSettings.xml contains <HTTPS enabled=”true” name=”…” />
If HTTPS is enabled: try connecting with your machine name instead of localhost.
If HTTPS is disabled: check if IIS is running
Hugo Andrade [SLC] [DevOps Member] commented 20th June 2022
Hi Jens, I think that HTTPS is disabled but IIS is running.
Lander Vanhaverbeke [SLC] [DevOps Member] commented 20th June 2022
Hi Hugo. What DataMiner version are you running?
Can you try connecting to the DMA again, and than send me (here or privately) the last 50 log lines of the log file of today in %localappdata%SkylineDataMinerDataMinerCubeLogs
Hi Lander, I’m using version 10.0.1947.5730, but I’m not finding the file you asked for.
Hugo Andrade [SLC] [DevOps Member]213 Posted 23rd June 2022 0 Comments
I managed to solve the error. It was a problem with the cluster because the ip addresses were conflicting with each other.
Thanks to everyone that tried to help!
