Problem with displaying trends on the dashboard
Solved1.59K views30th January 2024
Jaroslaw Burtny [DevOps Member]756 26th January 2024 0 Comments
Hi ALL.
Why can’t I display TRENDS for querying the table but for taken for the parameter table, I can ?
Is there anything I can change in the settings to do this?
The screen from QUERIES to Service table
The screen from table parameters SERVICE as below:
Where could the problem be?
Big tahnks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th January 2024
Ward Haeck [SLC] [DevOps Advocate]3.55K Posted 26th January 2024 1 Comment
Hi Jarek,
As Robin suggests you can feed the parameter of the selected row to a line chart:
  1. Add a line & area chart to your dashboard
  2. Select a row in your table
  3. Go to FEEDS and select your table
  4. Drag Parameters on the Line & Area chart
The end result will look something like this:
Hope this helps!
Best regards, Ward
Ward Haeck [SLC] [DevOps Advocate] commented 26th January 2024
If you are working in a low code app, you could also try to use on click actions to, for example, navigate to the monitoring app on click of a table cell. More info on further styling and adding additional functionality to your table can be found here:
https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/Low_Code_Apps/Tutorials/Tutorial_Apps_Style_A_Table.html
Robin Debel [SLC] [DevOps Enabler]2.26K Posted 26th January 2024 1 Comment
Hi Jarek.
The simple answer is it is not possible to do this in the GQI Table.
You could however feed the selected row of the GQI table to a parameter table and in this way keep the ability to click open its graph.
Another posibility is to feed the selected row to a line chart.
Robin Debel [SLC] [DevOps Enabler] Edited answer 29th January 2024
Jaroslaw Burtny [DevOps Member] commented 26th January 2024
Hi Robin.
Can you show me how to do this as this is my first step?
Br.
Jarek
