Problem with connection https:// to DMA
Solved2.50K views22nd November 2022HTTPS
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.36K 3rd November 2022 0 Comments
We have an issue connecting to a DMA via https. The certificate we have is valid and we are using FQDN:
Despite this, we get this error:
I did the configuration on the IIS server and in the file C:\Skyline DataMiner\MaintenanceSettings.xml as below
<SLNet>
<ConnectionCheckInterval clients="10" slnet="10"/>
<FlushQueuedMessagesInterval>100</FlushQueuedMessagesInterval>
<AutoDisconnectTime>3600</AutoDisconnectTime>
<CallbackTimeout>30</CallbackTimeout>
<ConnectionRetryInterval>10</ConnectionRetryInterval>
<TicketExpirationTime>300</TicketExpirationTime>
<DetectHangingCallsInterval>300</DetectHangingCallsInterval>
</SLNet>
<HTTPS enabled="true" name="*.<organization>.local"/>
<Network bitRateTracking="true"/>
</MaintenanceSettings>
Is the error due to the presence of the wildcard in the HTTPS tag ? TIA 🙂
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 22nd November 2022
Bert Buysschaert [SLC] [DevOps Advocate]5.32K Posted 3rd November 2022 0 Comments
Hi Arunkrishna,
This is a default security prevention in Internet Explorer and is not related to the certificates or DataMiner configuration. You will need to add the DMA to either the Trusted Sites or Local Intranet in the Internet Properties.
You could add https://*.company.local to cover all future agents.
Bert Buysschaert [SLC] [DevOps Advocate] Answered question 3rd November 2022
