Problem with Cassandra Cluster Migration
Solved1.50K views31st January 2024Cassandra SLCCMigration
Chris Glover [DevOps Advocate]1.87K 4th December 2023 1 Comment
I'm building a Dataminer test system, consisting of 6 DMA's, each a failover pair, using the default install with local Cassandra. DMAs built with 10.3.12. There are no elements deployed, this is a completely fresh DMS. The goal has always been to use Cassandra and Opensearch Clusters for this system. Both the clusters are ready for action.
When I run SLCCMigration, after I acknowledge the warning about failover clusters detected, I just get an empty window, showing a single line of text
SLDataGateway.Tools.CassandraCluster.Migration.UI.ViewModels.MainViewModel
When I'd tried this before on a single host, I got a window with an intialise button.
What am I doing wrong?
Thanks
Chris
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 31st January 2024
Mykyta Deyneha [SLC] commented 4th December 2023
Hi Chris, I’m not sure whether that could be a UI bug, could you provide us with the errors from the logging files? Also, just to be sure, are you running the migration tool with a working DataMiner (online)?
Xander Warszawski [SLC] [DevOps Advocate]331 Posted 4th December 2023 6 Comments
Hi Chris,
Could you check following files in "Skyline DataMiner\Logging":
- SLDataGateway_CC_Migration.txt
- SLCassandraMigration.txt
I can't remember the exact error message but if something similar to "could not initialize" would be present in there a restart will fix it.
I unfortunately don't know if this can be fixed without restarting.
Kind regards,
Xander
Chris Glover [DevOps Advocate] commented 4th December 2023
Brilliant!
I’ll check those two files.
The DMS has no elements yet, so restarting is not a problem, need to reboot to install windows updates anyway!
Thanks
in SLCssandraMigration, I have…
2023-12-04 15:01:51.443|29|PollStorageTypes. System.Exception: No connection set.
at SLCassandraClassLibrary.DBGateway.DBGateway.GetInfoOfStorageTypes()
at SLCassandraClassLibrary.DBGateway.ManagementController.PollStorageTypes(Object sender, ElapsedEventArgs args)
Xander Warszawski [SLC] [DevOps Advocate] commented 4th December 2023
Can you check if a restart solves this? This bug will be fixed in the next release but a restart can also fix this.
I rebooted the server, and got the same error
Xander Warszawski [SLC] [DevOps Advocate] commented 5th December 2023
The error appearing in these logs isn’t that uncommon. The UI could however work after a restart, can you check that again?
Show 1 more comments
