Prerequisite VerifyNoLegacyReportsDashboards failed for upgrade for 10.4.3 -> 10.4.6
Solved2.91K views29th May 202410.4.3 10.4.6 Dataminer core NoLegacyReportsDashboards
Gerwin van der Kamp [DevOps Advocate]4.09K 29th May 2024 0 Comments
I’m trying to update our staging environment to 10.4.6 in preperation of an production upgrade. however i got an BPA fail which already failed (and fixed) when upgrading to 10.4.3:
– Prerequisite VerifyNoLegacyReportsDashboards.dll failed: The system contains one or more legacy reports or legacy dashboards which might still be used. Either delete those first, or activate the soft-launch flag to keep on using the Legacy Reports and Dashboards. See https://aka.dataminer.services/VerifyNoLegacyReportsDashboards for more info.
Current version we are running is DataMiner (10.4.3.0-14001) so the reports and dashboards isn’t available any more.
How can i resolve this stand-off with my staging?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 29th May 2024
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 29th May 2024 6 Comments
I experienced the exact same thing yesterday and was going to edit the docs to make this clearer.
The files are located in C:\Skyline DataMiner\reports & C:\Skyline DataMiner\Webpages\Dashboards\db.
If you remove all of the aspx and config files in there you should be good to go.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Posted new comment 28th June 2024
Gerwin van der Kamp [DevOps Advocate] commented 29th May 2024
they are all empty except for an PlaceHolder.txt in C:Skyline DataMinerWebpagesDashboardsdb
Toon Casteele [SLC] [DevOps Enabler] commented 29th May 2024
Webpages\Reports\templates\Templates.xml should also have no child nodes apparently.
Just empty the whole folder or edit the Templates.xml?
Probably it can’t hurt in either case, but removing the file or emptying the nodes in it should do the trick in the safest way.
renamed the file and it passed the check.
Show 1 more comments
João Severino [SLC] [DevOps Enabler]14.78K Posted 29th May 2024 0 Comments
Hi Gerwin,
To view any dashboards or reports you may still have in your system you may temporarily enable the LegacyReportsAndDashboards soft-launch option and check the modules.
After deleting what you don’t need you may remove the flag again and the upgrade should work.
João Severino [SLC] [DevOps Enabler] Answered question 29th May 2024
Gerwin van der Kamp [DevOps Advocate]4.09K Posted 29th May 2024 0 Comments
But i had the same Prerequisite fail when upgrading to 10.4.3 and i removed all reports and dashboards at that point before i upgraded.
The C:\Skyline DataMiner\reports\ is empty
& in C:\Skyline DataMiner\Webpages\Dashboards\db is only a PlaceHolder.txt
Why does the Prerequisite fail?
Gerwin van der Kamp [DevOps Advocate] Answered question 29th May 2024
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 29th May 2024 2 Comments
Hi Gerwin,
You either delete the old reports and dashboards (C:\Skyline DataMiner\reports\),
or you add and enable the soft launch option “LegacyReportsAndDashboards” (for each DMA).
More info: Overview of soft-launch options | DataMiner Docs
Matthias Declerck [SLC] [DevOps Advocate] Posted new comment 17th March 2025
Vivek Kumar [DevOps Member] commented 12th March 2025
Hi Matthias,
I was facing the same issue while upgrading from 10.3.7.0 -> 10.4.5.0. I added the LegacyReportsAndDashboards soft launch option(since we don't want to delete existing dashboards), ran the Configure IIS file as per documentation and restarted DMA. I still see the same error when trying to upgrade.
I was looking for a solution in Dojo and found this. I could start a new question if necessary. Please advice.
Matthias Declerck [SLC] [DevOps Advocate] commented 17th March 2025
Hi Viktor, I advice to create a UOSA ticket or task and mention data exploration in the description.
