POST Request with Credentials in Body (Session syntax)
Solved2.06K views7th July 2023HTTP JSON Body post request session
Carys Blackburn [DevOps Advocate]723 3rd February 2023 0 Comments
Hi Skyline,
Is there anyway to use the Session syntax to send a POST Request that requires the credentials to be in the json body of the request?
Thanks
Laurens Moutton [SLC] [DevOps Enabler]9.91K Posted 3rd February 2023 0 Comments
In this link, there is an example shown of a POST request with <Data pid=”101″></Data>. Parameter with id 101 can then contain as value the json content to be present in the body of the message when sending the POST request.
Regards,
