Possible to use Visio 3-D Formated shapes in Cube
Solved2.38K views17th March 2021Cube Visio
Steve Purcell [SLC] [DevOps Advocate]2.69K 21st January 2021 0 Comments
When using Visio Format Shape option and applying 3-D formats to the shape (i.e. Top Bevel), the formatting seems to get removed when displayed in Dataminer Cube.  the 3-D formatted shape just displays as the standard rectangle.
Is there a way to have Cube support the Visio 3-D formatting?
Steve Purcell [SLC] [DevOps Advocate] Selected answer as best 17th March 2021
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 21st January 2021 2 Comments
The 3-D format is currently not supported by the Visual Overview and will ignore any configuration made in this section.
A possible workaround is to style a shape with your desired 3-D format and then take an image of that shape.
Steve Purcell [SLC] [DevOps Advocate] commented 21st January 2021
Thank you Sebastiaan. I think the workaround will work nicely.
Toon Casteele [SLC] [DevOps Enabler] commented 22nd January 2021
Do note that images can’t modify their fill color, meaning things like showing their alarm color as the background in the shape will not work.
