Populate card variable when using hyperlink
Solved2.00K views18th July 2023card variable hyperlink
Emmanuel Dal [SLC] [DevOps Member]4.63K 16th June 2021 3 Comments
I’m using the hyperlink feature to open an Element card from an alarm record. I would like to further extend the integration to also populate a card variable with the content of an alarm property so that the Visio assigned to the Element can highlight relevant data. Is this supported ?
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 16th June 2021
Sounds like this would be a very cool new feature!
Jarno Lernou [SLC] [DevOps Enabler] commented 16th June 2021
I’m not too sure on my answer, hence my comment in here. Would it be possible to use the engine methods CreateKey(string variablename) and ‘AddScriptOutput’? These methods were introduced to populate session variable when you open a Visio.
Ref DM Help: https://help.dataminer.services/dataminer/index.html#t=DataMinerUserGuidepart_2visioLinking_a_shape_to_an_Automation_script.htm
Emmanuel Dal [SLC] [DevOps Member] commented 16th June 2021
Many thanks for suggestion Jarno. Unfortunately , that only works with session variable ( not card variable) and script needs to be launched from Visual Overview. And I would prefer to not have script execution in the process.
Masschelein Karl [SLC]180 Posted 16th June 2021 0 Comments
Hi Emmanuel,
The alarmconsole hyperlink functionality doesn’t support this configuration (yet).
Maybe you could work with an alarm visioshape referring to the alarm record and use following visio functionality :
– link the alarm visio shape to the elementcard
– trigger a setvar to create a sessionvariable holding the alarmproperty value
– an initvar could then use that sessionvariable to populate the card variable
Kind regards,
Karl
