Play a sound when display a shape.
Solved2.23K views18th July 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate]945 2nd June 2021 0 Comments
Is it possible to play the following path sound in the client when shape is displayed in “Show” syntax etc.?
C:\\Windows\Media
It would be even more wonderful if could also choose looping, number of plays, etc.
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 2nd June 2021 0 Comments
Hi Yuki,
Next to the options mentioned by Miguel, there is also an option to have audible alerts feature available in DataMiner cube.
Please find below a sample configuration.
More detailed information can be found here in the dataminer help.
Miguel Obregon [SLC] [DevOps Catalyst]23.76K Posted 2nd June 2021 0 Comments
Hi Yuki,
As far as I know this is not supported.
A possible workaround is using the DMS Alerter. The alerter is a system tray application that can be used to play sounds in the client when an alarm is generated in the DMS.
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 2nd June 2021
