Passing variables in to automation script with a correlation rule
Solved231.92K views19th July 2023Automation script Correlation rule
Oliver Jarvis-King 7th January 2021 0 Comments
Hi. Does anyone know if it’s possible to pass variables in to an automation script that’s executed through a correlation rule?
For example…
I have a script that I can use to shut/open a network interface, and this script requires three variables; element name, interface, desired state (shut/open).
I have a correlation rule that may require a specific network interface to be bounced, and all the required information is contained within the correlated alarm.
Can I automatically extract the required information from the correlated alarm and pass it through to the automation script when it gets executed as part of the correlation rule actions?
I hope that makes sense. Thanks.
Miguel Obregon [SLC] [DevOps Catalyst]23.86K Posted 7th January 2021 0 Comments
Hi Oliver,
Yes, this is possible. In the automation script you can retrieve information from the alarm that triggered the correlation rule. I believe that the alarm that triggered the correlation rule will be based on the interface that you would like to update.
Information about how to process information from a correlation rule in an automation script can be found in the DataMiner Help:
  • Special parameters available in DMS Automation scripts
  • How do I parse Correlation Alarm Info data?
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 7th January 2021 0 Comments
Hi Oliver,
Besides the answers from Miguel and Tim, I would like to highlight a hands-on video created for the Automation course, available on Dojo. You can find the video over here: Executing scripts from Correlation
Jarno Lernou [SLC] [DevOps Enabler] Answered question 7th January 2021
Tim Vandenbruwaene [SLC] [DevOps Member]2.29K Posted 7th January 2021 0 Comments
Not sure if this would help, it allows you to parse the correlation alarm info https://help.dataminer.services/dataminer/DataMinerUserGuide/part_4/automation/How_do_I_parse_Correlation_Alarm_Info_data.htm#XREF_65796_30_6_5_How_do_I
Tim Vandenbruwaene [SLC] [DevOps Member] Answered question 7th January 2021
