PA – Is it possible to reuse IDP activities in custom flow
Solved2.04K views3rd October 2023IDP process automation
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 29th September 2023 0 Comments
We are building a Process Automation flow and are wondering how far we can include some of the IDP activities? The one we would like to include is for creating/provisioning an element based on CI Type and IP address. Is this possible?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 3rd October 2023
João Severino [SLC] [DevOps Enabler]14.52K Posted 29th September 2023 0 Comments
Hi Jens,
Yes, it should be possible to do what you are after.
IDP Activities are "modular" and can be included in other Process Automation flows, being just a single activity or multiple ones.
You can see an example with the IS-04 integration
João Severino [SLC] [DevOps Enabler] Answered question 29th September 2023
