PA – Is it possible to reuse IDP activities in custom flow
Solved2.03K views3rd October 2023IDP process automation
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 29th September 2023 0 Comments
We are building a Process Automation flow and are wondering how far we can include some of the IDP activities? The one we would like to include is for creating/provisioning an element based on CI Type and IP address. Is this possible?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 3rd October 2023
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.53K Posted 2nd October 2023 0 Comments
The IDP activities were initially designed as resource-related tasks for PA versions prior to 1.3. They possess unique interface specifications distinct from the current IN and OUT standards recommended for PA 1.3 and later. Consequently, their integration with other activities in PA 1.3 and beyond may pose challenges in terms of reusability.
Nevertheless, we have introduced script task activities aimed at facilitating the provisioning of elements and executing rack assignments. These activities align seamlessly with PA 1.3 guidelines, and I am confident they can be of assistance to you.
For more detailed information, I will share the specifics with you via email.
João Severino [SLC] [DevOps Enabler]14.52K Posted 29th September 2023 0 Comments
Hi Jens,
Yes, it should be possible to do what you are after.
IDP Activities are “modular” and can be included in other Process Automation flows, being just a single activity or multiple ones.
You can see an example with the IS-04 integration
João Severino [SLC] [DevOps Enabler] Answered question 29th September 2023
