OID to Name conversion
Solved1.60K views18th July 2024
Richard Wilkins98 16th January 2024 2 Comments
I have a question about pulling out name vs OID in DIS
Here is what I have for the parameter
<Param id=”1002″ trending=”false”>
<Name>lgpConditionsLgpConditionDescr</Name>
<Description>Lgp Condition Descr (Lgp Conditions)</Description>
<Information>
<Subtext>
<![CDATA[A reference to a condition description object. The object
referenced should not be accessible, but rather be used to provide
a unique description.]]>
</Subtext>
</Information>
<Type>read</Type>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<SNMP>
<Enabled>true</Enabled>
<OID type=”complete”>1.3.6.1.4.1.476.1.42.3.2.3.1.2</OID>
<Type>objectid</Type>
</SNMP>
<Display>
<RTDisplay>true</RTDisplay>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
The mib parameter contains
Name
OID
MIB
Description
The description contains no info but the name will do since it is readable.
The driver pulls up OID info which is not practical.  I was wondering if someone knows how to return the name portion as opposed to the OID
Miguel Obregon [SLC] [DevOps Catalyst] commented 26th January 2024
Hi Richard,
Please could you elaborate a bit more your question?
What do you mean with ‘how to return the name portions as opposed to the OID’?
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th April 2024
Hi Richard,
I see this question has been inactive for some time now. Do you still need assistance with this? If yes, could you answer Miguel’s questions? Or if you have found the solution by now, could you add an answer with some info for reference for other users who may be facing the same problem?
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 18th July 2024 0 Comments
As this question has now been open for a long time and there has been no further reaction from you, I will now close it. If you still want more information about this, could you post a new question?
