Node-Edge : How can I draw 1 line between my switches instead of 4?
Solved3.62K views13th September 2021Dashboards node-edge
Jens Vandewalle [SLC] [DevOps Advocate]10.09K 10th September 2021 0 Comments
In Dashboards I'm using the node-edge component to visualize my network of leaf (blue) and spine  (purple) switches.
Now I want to only see 1 connection between my leaf and spine switches, even when there are multiple physical connections between them. What do I need to add to below query to achieve this?
Note that I still want to see the multiple connections between my spine switches.
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 13th September 2021
Jarno Lernou [SLC] [DevOps Enabler]6.09K Posted 10th September 2021 0 Comments
Hi Jens, I don't know your exact query for the connections, but I think you need two different queries for them. The easiest way to validate everything is to visualize the query in a table form. By doing this, you will see all results from the query.
Assuming you are using the interface ID to identify nodes, you will need to find a filter that you only have one result (row) for each pair of connected interfaces.
Jarno Lernou [SLC] [DevOps Enabler] Answered question 10th September 2021
