Node Edge component – override filter RegEx
Solved2.07K views28th August 2023node-edge Regex
André Kaiser [DevOps Enabler]532 22nd August 2023 0 Comments
in Node Edge we can define nodes with their shape, colour, icon, etc. It is also possible to define override nodes when a certain filter criteria is matched by available parameters of the node. Currently I see that the only option is to have a Filter “{Parameter} is {string} “. This works perfect if we e.g. take the name and specify the full name in the filter. Can the string also be a RegEx? This would allow us to filter for nodes with a common part in their name and apply e.g. another colour for these nodes.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2023
Miguel Obregon [SLC] [DevOps Catalyst]23.66K Posted 23rd August 2023 1 Comment
Hi Andre,
As far as I know this is not possible. Maybe an option could be adding more than one query to your node component (with specific filters) that can be used as nodes. You could implement the filter that you are looking for in the GQI query itself.
Hope it helps.
André Kaiser [DevOps Enabler] Posted new comment 31st August 2023
André Kaiser [DevOps Enabler] commented 31st August 2023
Many thanks Miguel. Adding variations of the queries provided the expected result.
