Network adaptor not working after failover
Solved9.74K views6th October 2020Failover
6
Ive Herreman [SLC] [DevOps Enabler]14.78K 6th October 2020 0 Comments
When performing a restart or failover of our DataMiner system, one of the NICs becomes unusable.
Even sending out a ping over that NIC stops working.
Disabling & Enabling the NIC again solves the issue (until the next restart).
Does someone know the exact set of actions that are performed on the NIC during startup/failover?
Ive Herreman [SLC] [DevOps Enabler] Selected answer as best 6th October 2020
Michiel Saelen [SLC] [DevOps Advocate]6.55K Posted 6th October 2020 2 Comments
Hi Ive,
Do you have this for all your DMA's?
Could you also share some more information on the Windows version, DataMiner version, driver and HW info on your adaptor?
Michiel Saelen [SLC] [DevOps Advocate] Posted new comment 6th October 2020
Ive Herreman [SLC] [DevOps Enabler] commented 6th October 2020
Hi Michiel,
Thank you for your response.
My cluster contains only one DMA (failover pair).
The system is running DataMiner 10.0.9 on windows server 2012R2.
The NICs are “RedHat Virt IO” network adaptors (which have been working fine for the the last 2 years).
I have 4 NICs but only the primary dataminer nic has this problem.
The logging shows no errors.
Michiel Saelen [SLC] [DevOps Advocate] commented 6th October 2020
Could it be related with assigning the virtual IP?
