NATS & IPC: what info is exchanged via NATS in a cluster (DM 10.x – and on)?
Solved2.34K views3rd February 2025adl20299 IPC NATS SLNet
Alberto De Luca [DevOps Enabler]5.75K 21st June 2024 2 Comments
I seem to recall since DM10, specific ports became required in a cluster for the usage of NATS.
What info is actually exchanged via the NATS service?
What is still relying on SLNet instead?
Thanks
Alberto De Luca [DevOps Enabler] Selected answer as best 3rd February 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 22nd November 2024
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 27th August 2024 0 Comments
Hi Alberto,
I’ve checked with the Data Core team, and it appears that NATS is used for too many things to easily be able to enumerate this here. However, the most important ones are DxM communication, parameter changes, and alarms. Laurens also provided some more information about this here: https://community.dataminer.services/question/nats-service-ipc-is-it-actually-required-in-a-cluster/
Jordy Ampe [SLC] [DevOps Advocate]2.00K Posted 24th June 2024 1 Comment
I’ll let someone else reply for the DataMiner part, but for the DxMs regarding the cloud functionality almost all the communication between those DxMs goes over NATS in the cluster.
An example where NATS is explicitly not used for, as it’s not made for that, is transferring (large) files. That’s why we introduced the need for port 5100 with the cloud DxMs, so that each DxM could proxy files(/requests) over HTTPS to the right server or to dataminer.services via the CloudGateway. As an example for that your have Catalog and DxM deployments from dataminer.services, or Remote Log Collections towards dataminer.services.
Alberto De Luca [DevOps Enabler] Unselected an answer 3rd February 2025
Alberto De Luca [DevOps Enabler] commented 24th June 2024
Thanks, Jordy – that’s a start – leaving the topic open as I need to retrieve info also outside of the DxM side.
