MouseOver not working with Element/Parameter
Solved1.54K views17th July 2023togglebutton Visio Visual Overview
Robin Becker [DevOps Member]1.42K 20th January 2022 0 Comments
I have a toggle button which also displays Parameter information.
However when adding the shape data Element, Parameter and ParameterSubscriptionFilter on all the child shapes in the group the mouse over effect stops working.
Is there a way around this?
EDIT:
Miguel Obregon [SLC] [DevOps Catalyst]22.14K Posted 21st January 2022 3 Comments
Hi Robin,
Whenever you add a Element shape data to a shape, the shape will automatically be converted to a hyperlink to the element.  Can you try adding the shape data ‘Enabled’ with the value ‘False’? (Disabling the default hyperlink behavior of a linked shape)
Robin Becker [DevOps Member] commented 21st January 2022
I’m guessing you mean setting it to value ‘False’? ‘Disabled’ actually made it a hyperlink again and ‘False’ didn’t have any effect.
Miguel Obregon [SLC] [DevOps Catalyst] commented 21st January 2022
Indeed, I meant ‘False’. I updated the answer accordingly.
If possible, can you include some screenshots to your question so we can check if there is a workaround?
See edit for screenshots.
