Method for Upgrade Packages to other agents through System Center in Cube?
Solved2.52K views18th July 2023File Transfer SLNet upgrade
Michael Wells [SLC] [DevOps Member]502 8th November 2021 0 Comments
I am trying to troubleshoot slow file transfers between certain agents that are located in different security zones and firewalls federate the traffic between agents.
For agents within a security zone, it takes about 3 minutes to upload a full upgrade file (500MB+), vs 20 minutes+ for uploading to agents in a different security zone through the firewall.
After doing a wireshark, it looks like we are sending an HTTP message over port 8004 that has an encrypted payload.  Is this a file transfer packet?
If not, what method are we using to transfer upgrade packages between agents in a cluster?
Gellynck Jens [SLC]2.73K Posted 9th November 2021 3 Comments
Hi Michael,
The HTTP requests you're seeing are the .NET Remoting (which is actually wrapped in HTTP communication) that DataMiner uses to communicate with clients and other DataMiner agents. (these are compressed and encrypted)
The upgrade package will indeed transfer over these .NET Remoting (or HTTP) requests.
Gellynck Jens [SLC] commented 9th November 2021
Good to know, we are phasing out .NET Remoting, from 10.2.X onwards it will be replaced by gRPC which has better performance and security.
Michael Wells [SLC] [DevOps Member] commented 9th November 2021
What will be the port requirements for gRPC?
gRPC will always go over HTTPS (so port 443 by default)
