MemoryUsage tag in automation script
Solved1.95K views12th July 2023Automation script MemoryFile MemoryUsage
Pawel Bochenek [DevOps Member]736 28th October 2022 0 Comments
Hello,
I recently imported an existing automation script into VS using the DIS plug-in and noticed a new tag in the xml file called <MemoryUsage> containing over two thousand of <MemoryFile> sub-tags listing the persistent memory files used by the script when executed. It appears that new entry is created every time the script runs and accesses any of the memory files. Are these necessary and what is the purpose of logging this information in the automation script itself?
<MemoryUsage>
<MemoryFile>mem_file_name_x</MemoryFile>
<MemoryFile>mem_file_name_y</MemoryFile>
<MemoryFile>mem_file_name_z</MemoryFile>
</MemoryUsage>
Many thanks.
Wouter Demuynck [SLC] [DevOps Advocate]7.08K Posted 3rd November 2022 1 Comment
Hi Pawel,
These <MemoryFile> tags are indeed generated when executing scripts.
As far as I know, the only use for this info is to be able to export these memory files along with automation scripts.
There was an issue before DataMiner v9.6 where duplicate entries got added to the list (RN19981). What you are seeing might be a remnant of this.
I believe you can trigger a clear of the list by making a small change and re-saving the script from the Cube Automation UI.
Pawel Bochenek [DevOps Member] commented 4th November 2022
Thank you Wouter. Indeed, this script for created some time ago, most likely before v9.6.
