Mamipulating views in automation script
Solved1.58K views18th July 2023Automation script Visio views
Erik Andrae 5th November 2021 0 Comments
Hello.
I have a case where I want to run a script via the Execute property in a Visio shape, then show some data calculated in this script in the Visio shape. Is there any way to transmit data without using a parameter? Can I for example set a session variable or return something?
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 5th November 2021 0 Comments
Hi Erik,
Please have a look at DataMiner Help - Linking a shape to an automation script (Passing Automation script output to session variables)
