Low-Code Grid on-click event
Solved2.01K views24th February 2025grid low-code
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 24th February 2025 0 Comments
In the latest kata an on-click event is used on the grid shapes.
I can’t seem to find where to configure this.
I thought it would be in the component settings, but it isn’t.
How is this done?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 24th February 2025
Wout Mahieu [SLC] [DevOps Catalyst]12.45K Posted 24th February 2025 0 Comments
Hi Jeroen,
On click actions for a shape can be configured in the shape properties when the shape is selected. Note that actions are only available in LCA and not for text shapes.
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.58K Posted 24th February 2025 0 Comments
Hi Jeroen,
The click event is managed within the grid’s template. You can locate it in the properties panel on the right side when a rectangle or icon layer is selected.
Please be aware that actions are currently permitted only in apps, so this feature isn’t available in dashboards.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Answered question 24th February 2025
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K Posted 24th February 2025 0 Comments
Nevermind, I found you need to create a shape in the Grid Template Editor and define the On-Click event there
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 24th February 2025
