Low Code Apps – logging (best practice)
Solved2.41K views5th July 2023logging low code apps
Jens Vandewalle [SLC] [DevOps Advocate]10.00K 12th June 2023 0 Comments
I'm building some Low Code Apps and need a way to log information for debugging purposes, providing additional information, etc.
Not sure if there already something that I can reuse? If not, I'm eager to build something myself, but I'm looking for some best practices input since I can think of a few approaches to make this available:
  • store logging in logger tables (make use of aliases for each application)
  • store the data in separate files (like done for the SRM framework)
  • make the data for each application individually available in DOM
  • create 1 DOM module for logging purposes
Emmanuel Dal [SLC] [DevOps Member]4.63K Posted 12th June 2023 0 Comments
Jens,
What is done in SRM has few drawbacks, due to the fact that it requires a shared folder accessible from all DMAs of a cluster.
There is also a LogHelper API available (RN26434) ; however there is no UI to visualize log records. You could of course implement an ad-hoc data source to retrieve them.
Emmanuel Dal [SLC] [DevOps Member] Answered question 12th June 2023
