Low Code Apps : Custom themes and application package
Solved1.27K views22nd March 2024custom themes low code app
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.05K 22nd March 2024 0 Comments
Dojo,
I have designed a Low Code App (LCA) with custom themes on my local DMA. With an application package I intend to be able to ship this app to any other DMS but I noticed my custom themes are not carried along as part of the LCA.
  1. How can I have my custom themes as part of the application package so that its installed seamlessly on any other DMS ?
  2. If above is not possible any advise on how I should design my app with this limitation in mind ?
Wale Oguntoyinbo [SLC] [DevOps Advocate] Selected answer as best 22nd March 2024
Wout Mahieu [SLC] [DevOps Catalyst]11.61K Posted 22nd March 2024 3 Comments
Hi Wale,
Custom dashboard themes are stored in a separate file (C:\Skyline DataMiner\dashboards\Themes.json) that you could include in the package. Be aware that overwriting this file will remove all existing custom themes.
Wout Mahieu [SLC] [DevOps Catalyst] Posted new comment 25th March 2024
Wale Oguntoyinbo [SLC] [DevOps Advocate] commented 22nd March 2024
This is very insightful. Thanks.
Ive Herreman [SLC] [DevOps Enabler] commented 22nd March 2024
Is there a way we could inject a theme in the existing config, without removing the existing configurations (or something on the roadmap)? Currently deploying a package with a theme, removes the themes from a previously deployed package.
Wout Mahieu [SLC] [DevOps Catalyst] commented 25th March 2024
You should be able to modify the install script of the package to inject a new custom theme in the existing file instead of including the entire theme file
