Low-Code Apps as soft-launch not visible in license overview
Solved1.72K views30th March 2023soft-launch options
Jordy Bekaert [SLC] [DevOps Advocate]2.03K 29th March 2023 0 Comments
Hi, the Low-Code Apps license has been enabled on a Staging agent running version 10.2.0.0-12603-CU11. Since this DMA is not running 10.2.5 yet, the soft-launch option got enabled.
Even though the license has been enabled, Low-Cope Apps is not visible in the license overview:
We assume that the reason of this is having Low-Code Apps enabled as a soft-launch option, and this license will only appear in this overview once fully available in 10.2.5.
Would our assumption be correct?
Jordy Bekaert [SLC] [DevOps Advocate] Selected answer as best 30th March 2023
Wim Bruynooghe [SLC] [DevOps Advocate]6.77K Posted 29th March 2023 0 Comments
“Low-Code Apps” will only be shown in the license overview in Cube from 10.2.6 onwards (RN33208). In older versions you don’t need the license, Low-code Apps will work if the soft-launch flag is enabled.
6
Jan Vanhove [SLC] [DevOps Member]1.23K Posted 29th March 2023 1 Comment
Hey Jordy, low-code apps are in this version still under soft-launch.  Can you check if the soft-launch flag is activated?
Overview of the flags can be found here.
Martin Vrzba [DevOps Advocate] Posted new comment 29th March 2023
Martin Vrzba [DevOps Advocate] commented 29th March 2023
The low-code app indeed works in soft-launch even when it is not listed in the list of licenses. Thank you.
