Low Code App : Display dynamically a web component or texte inside a web component
Solved2.04K views29th February 2024low code app low code apps
Yvan Barbotin [DevOps Member]50 27th February 2024 0 Comments
Hi community,
I would like to display dynamically a text inside a web component.
The use case is to warn users of maintenance windows with, for example, a message like "Update scheduled for 1 March, the low code app will not be available between 10am and 11am".
I don't want to publish a new app every time I want to update the message.
Thanks for your help
Ive Herreman [SLC] [DevOps Enabler] Answered question 29th February 2024
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 27th February 2024 1 Comment
Hi Yvan,
You could use the DataMiner Object Model.
Create a DOM definition and an instance.
The instance can easily be updated from the same or a different low-code app.
You can then use a GQI query to retrieve your message.
Alternatively, you can also create an ad-hoc data source and read it from somewhere else e.g. a file or similar.
Ive Herreman [SLC] [DevOps Enabler] Answered question 27th February 2024
Yvan Barbotin commented 27th February 2024
Thanks Ive for your answer.
I tried to implement something but I have issue.
To have a dynamic text, I use a grid component (I don’t think it’s possible with a web component as we can’t use query result in this type of component)
Then I use a html code to have my text but this text is not the same when I use web component and grid component. It doesn’t use the full width of my shape and the result is not nice.
Code example below (to generate a scrolling message : Test message)
<div style="display: inline-block;
animation: scroll 12s linear infinite;
padding: 0 25%;
font-family: 'Segoe UI Light', 'Segoe UI Web Light', 'Segoe UI Web Regular', 'Segoe UI', 'Segoe UI Symbol', HelveticaNeue-Light, 'Helvetica Neue', Arial, sans-serif;
font-weight: 100;
font-size: 20px;
Test message
Thanks
