Localhost connection error after agent installation
Solved3.03K views28th March 2025Errors firewall locahost locathost connection
Ashok Mahala [DevOps Member]249 17th September 2024 2 Comments
After applying the license when I am trying to connect with Dataminer Cube using localhost after giving credentials one error is coming.
I have attached the error screenshot. Can anyone please help me to solve this issue. I have disabled firewall and restarted the system. I am still facing this issue.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th January 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Seppe Dejonckheere [SLC] [DevOps Enabler]2.98K Posted 18th September 2024 1 Comment
The HTTP timeout exception means that Cube was not able to retrieve the connectionsettings.txt file.
Since you made some configuration changes in IIS, would it be possible to share which bindings you currently have configured? It could also be usefull to have a look at the Cube logging (the DataMiner logging won't help in this case, as Cube is not even able to set up a connection).
Kind regards,
Ashok Mahala [DevOps Member] Edited comment 18th September 2024
Ashok Mahala [DevOps Member] commented 18th September 2024
Hello Seppe, I just uninstalled and reinstalled Cube now that problem is not there but when I am trying to login using my Administrator account it is saying user name or password is not correct. How can I fix this issue.
