Localhost connection error after agent installation
Solved3.07K views28th March 2025Errors firewall locahost locathost connection
Ashok Mahala [DevOps Member]249 17th September 2024 2 Comments
After applying the license when I am trying to connect with Dataminer Cube using localhost after giving credentials one error is coming.
I have attached the error screenshot. Can anyone please help me to solve this issue. I have disabled firewall and restarted the system. I am still facing this issue.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th January 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Ashok Mahala [DevOps Member]249 Posted 30th September 2024 0 Comments
Hello, I just uninstalled and reinstalled Cube now that problem is not there.
Seppe Dejonckheere [SLC] [DevOps Enabler]3.04K Posted 18th September 2024 1 Comment
The HTTP timeout exception means that Cube was not able to retrieve the connectionsettings.txt file.
Since you made some configuration changes in IIS, would it be possible to share which bindings you currently have configured? It could also be usefull to have a look at the Cube logging (the DataMiner logging won’t help in this case, as Cube is not even able to set up a connection).
Kind regards,
Ashok Mahala [DevOps Member] Edited comment 18th September 2024
Ashok Mahala [DevOps Member] commented 18th September 2024
Hello Seppe, I just uninstalled and reinstalled Cube now that problem is not there but when I am trying to login using my Administrator account it is saying user name or password is not correct. How can I fix this issue.
Ashok Mahala [DevOps Member]249 Posted 18th September 2024 5 Comments
// connectionsettings file
# This file contains default connection settings to be used for
# CLIENTS connecting from specific IP ranges
# Format:
# <set of ; spearated ip ranges> <options>
# IP Range types:
# 10.* (“start with” mask)
# 10.10.1.1-10.10.1.100 (range)
# 10.10.7.1 (single address)
# Options:
# type=RemotingConnection (connection type)
# polling=1000 (polling interval. 0=no polling)
# serverport=1234 (override port on which clients needs to connect. 0 = no override)
# zip=true (zipping needs to be enabled? true/false)
# cache=objects (defines which types of data can be cached on client side. Values: all, none, objects, events Default: objects)
# resolve=true (client needs to resolve hostnames to ip addresses before connect. Default: true)
# Examples
# 10.10.7.1 type=RemotingConnection;polling=1000;zip=true
# 10.11.*;168.* type=RemotingConnection;polling=1000;zip=false
# * type=RemotingConnection;polling=0;zip=true
# Comments
# Lines starting with a ‘#’ character are considered to be comments
# and are ignored.
# Notes:
# List the most specific ranges first. When looking up the settings
# for an IP address, the first matching IP range defines the settings.
# Add entries below:
# Do not add entries below the catch-all range below. The settings
# below apply to all client IP addresses for which none of the
# ranges above matches.
// slerror file
2024/09/18 01:41:47.314|SLLog|ApplyLogLevels|CRU|-1|Log Levels: Info: 5; Error: 5; Debug: 5 (init)
2024/09/18 01:41:50.515|SLWatchDog.txt|SLWatchDog.exe 10.2.2143.10376|13244|12364|CHardware::Init()|ERR|-1|Getting IP (192.168.200.130) row failed with reason: Element not found.(1168)
2024/09/18 01:41:50.515|SLWatchDog.txt|SLWatchDog.exe 10.2.2143.10376|13244|12364|CHardware::Init()|ERR|-1|Setting SkipAsSource flag for IP Address (192.168.200.130) failed with reason: The parameter is incorrect.(87)
2024/09/18 01:41:50.516|SLWatchDog.txt|SLWatchDog.exe 10.2.2143.10376|13244|12364|CHardware::Init()|ERR|-1|Getting IP (192.168.0.214) row failed with reason: Element not found.(1168)
2024/09/18 01:41:50.517|SLWatchDog.txt|SLWatchDog.exe 10.2.2143.10376|13244|12364|CHardware::Init()|ERR|-1|Setting SkipAsSource flag for IP Address (192.168.0.214) failed with reason: The parameter is incorrect.(87)
2024/09/18 01:41:59.647|SLWatchDog.txt|SLWatchDog.exe 10.2.2143.10376|13244|12364|CHardware::Init()|ERR|-1|Getting IP (192.168.200.130) row failed with reason: Element not found.(1168)
2024/09/18 01:41:59.648|SLWatchDog.txt|SLWatchDog.exe 10.2.2143.10376|13244|12364|CHardware::Init()|ERR|-1|Setting SkipAsSource flag for IP Address (192.168.200.130) failed with reason: The parameter is incorrect.(87)
2024/09/18 01:41:59.648|SLWatchDog.txt|SLWatchDog.exe 10.2.2143.10376|13244|12364|CHardware::Init()|ERR|-1|Getting IP (192.168.0.214) row failed with reason: Element not found.(1168)
2024/09/18 01:41:59.648|SLWatchDog.txt|SLWatchDog.exe 10.2.2143.10376|13244|12364|CHardware::Init()|ERR|-1|Setting SkipAsSource flag for IP Address (192.168.0.214) failed with reason: The parameter is incorrect.(87)
2024/09/18 01:43:08.334|SLDMS.txt|SLDMS.exe 10.2.2143.10770|6148|11568|CHardware::Init()|ERR|-1|Getting IP (192.168.200.130) row failed with reason: Element not found.(1168)
2024/09/18 01:43:08.335|SLDMS.txt|SLDMS.exe 10.2.2143.10770|6148|11568|CHardware::Init()|ERR|-1|Setting SkipAsSource flag for IP Address (192.168.200.130) failed with reason: The parameter is incorrect.(87)
2024/09/18 01:43:08.335|SLDMS.txt|SLDMS.exe 10.2.2143.10770|6148|11568|CHardware::Init()|ERR|-1|Getting IP (192.168.0.214) row failed with reason: Element not found.(1168)
2024/09/18 01:43:08.335|SLDMS.txt|SLDMS.exe 10.2.2143.10770|6148|11568|CHardware::Init()|ERR|-1|Setting SkipAsSource flag for IP Address (192.168.0.214) failed with reason: The parameter is incorrect.(87)
2024/09/18 01:43:18.015|SLASPConnection.txt|SLASPConnection.exe 10.2.2143.10598|6468|1360|CServiceModule::LoadIPAddresses|ERR|-1|Error 2 while fetching IP adapter info for SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{C719B7F1-ED62-43E2-97FB-34439E58F197} (DHCP=1)
2024/09/18 01:43:18.015|SLASPConnection.txt|SLASPConnection.exe 10.2.2143.10598|6468|1360|CServiceModule::LoadIPAddresses|ERR|-1|Error 2 while fetching IP adapter info for SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{23A5EA14-F079-4B01-8ADF-754F432A9192} (DHCP=1)
2024/09/18 01:43:18.015|SLASPConnection.txt|SLASPConnection.exe 10.2.2143.10598|6468|1360|CServiceModule::LoadIPAddresses|ERR|-1|Error 2 while fetching IP adapter info for SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{75A5D13A-41EA-4B51-8E27-2E3422672018} (DHCP=1)
2024/09/18 01:43:20.400|SLDataMiner.txt|SLDataMiner.exe 10.2.2143.11518|4132|12992|CHardware::Init()|ERR|-1|Getting IP (192.168.200.130) row failed with reason: Element not found.(1168)
2024/09/18 01:43:20.400|SLDataMiner.txt|SLDataMiner.exe 10.2.2143.11518|4132|12992|CHardware::Init()|ERR|-1|Setting SkipAsSource flag for IP Address (192.168.200.130) failed with reason: The parameter is incorrect.(87)
2024/09/18 01:43:20.400|SLDataMiner.txt|SLDataMiner.exe 10.2.2143.11518|4132|12992|CHardware::Init()|ERR|-1|Getting IP (192.168.0.214) row failed with reason: Element not found.(1168)
2024/09/18 01:43:20.400|SLDataMiner.txt|SLDataMiner.exe 10.2.2143.11518|4132|12992|CHardware::Init()|ERR|-1|Setting SkipAsSource flag for IP Address (192.168.0.214) failed with reason: The parameter is incorrect.(87)
Ashok Mahala [DevOps Member] Posted new comment 18th September 2024
Edib Šupić [SLC] [DevOps Enabler] commented 18th September 2024
Can you try replacing “* type=RemotingConnection;polling=0;zip=true” with “* type=GRPCConnection;serverport=443;endpoint=/APIGateway”? You will most likely have to setup HTTPS on IIS. You can follow this guide “https://docs.dataminer.services/user-guide/Advanced_Functionality/DataMiner_Agents/Configuring_a_DMA/Setting_up_HTTPS_on_a_DMA.html” and this Kata “https://community.dataminer.services/courses/kata-29/”
But i have not done any GRPC setup what should i do any reference document or video.
I have did the setup of https in IIS , i have applied self signed license also. After that when i tried to access the page using browser url with HTTPS it is giving error
This site can’t be reachedThe webpage at https://localhost/connectionsettings.txt might be temporarily down or it may have moved permanently to a new web address.
ERR_SSL_KEY_USAGE_INCOMPATIBLE
I think just configuring this file is enough to enable GRPC, and regarding your issue with certificate you will need to configure bindings for IIS, make sure your certificate is valid, and move it to Trusted folder in certificates manager. Certificates are delicate issue and might take some trial and error
I have tried all the possible ways nothing is working. If you can give a clear guidance it will be very helpful to continue my learning.
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 17th September 2024 5 Comments
Hi Ashok,
others have experienced similar issues before, for them issues were mostly related to firewall settings. Can you check out this post and see if it helps?
If the previous post doesn’t help you solve the issue can you have a look at some of these?
Hope this helps and let me know if you need anything else,
Cheers
P.S.
Please let me know how you resolved your issue(I’m curious), hopefully you will 😀
Hello Edib, I am not able to get anything much relevant from the questions you have shared. When i am trying to access the same URL from my browser i am able to access these pages using http but not with HTTPS, In Cube side also i have configured as Http or Https then why it is trying to access https if http is working then i should be able to connect with http right? Can you please look into or clear me the steps what i have to do ?
Hi Ashok,
Can you share your connectionsettings.txt and SLErrors.txt?
Yes I can, Please share me the mail where I have to share because here I can only attach media files.
You can just copy them here, I would suggest in a new comment instead under this one so you can format it a bit more nicely(it won’t be perfect either way, just nicer). You understand I can’t just post my mail here 😀
I have updated this content as Start a new answer please check and let me know where the problem is ?
