LCA – Timezone per LCA
911 views5th May 2026low code app Time Zone
Robin Devos [SLC] [DevOps Advocate]3.01K 4th May 2026 0 Comments
Is it possible to define a specific time zone for only 1 low code app?
We have an app in a global context, so we want to use UTC for this specific LCA.
There are also other LCAs that should remain on the local time.
I found
ClientSettings.json | DataMiner Docs
=> this is linked to the users, not the LCA
How do I ensure that Timestamps saved in UTC are also displayed in UTC in Low-Code-Apps/Dashboards? - DataMiner Dojo
"new feature that allows each user to set his timezone in the web apps themselves"
=> can this be done per web app and put as default for all users?
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 5th May 2026
Wout Mahieu [SLC] [DevOps Catalyst]12.47K Posted 5th May 2026 1 Comment
Hi Robin,
Both the ClientSettings.json as the new setting in the UI are on a user level. It is currently not possible to specify a time zone for a specific LCA.
If this is something you are interested in, I suggest you create a feature suggestion.
Robin Devos [SLC] [DevOps Advocate] Posted new comment 5th May 2026
Robin Devos [SLC] [DevOps Advocate] commented 5th May 2026
New feature requested
https://community.dataminer.services/new-feature-suggestions/lca-configure-time-zone-per-lca/
