LCA : Query filter feed component – Range filter
Solved1.19K views22nd October 2024LCA query filter range filter
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.39K 22nd October 2024 0 Comments
Dojo,
Is it possible to get rid off the range filter and have only the checklist in a query filter component ?
Wale Oguntoyinbo [SLC] [DevOps Advocate] Selected answer as best 22nd October 2024
Wout Mahieu [SLC] [DevOps Catalyst]12.33K Posted 22nd October 2024 1 Comment
Hi Wale
It is not possible to hide this filter, without modifying your data. It is shown because the underlying ‘MCR Status’ column is a discrete column with numeric values. You could modify this column to be discrete with string values instead.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Posted new comment 27th October 2024
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 27th October 2024
That’s correct Wout, although I believe the range selector should be hidden when the field solely consists of discretes. A task has been added to the backlog for this and we’ll notify everyone here once it has been completed.
