LCA: Node edge graph with limited data and hyperlink to device
Solved1.25K views26th June 2025
Apurva Tandon [DevOps Member]1.73K 7th February 2025 0 Comments
We have a LCA wherein we have node edge graph but it brings so much data which is not needed like node id and stuff, how can minimize that and also is it possible to have hyperlink for the device on that node edge so that by clicking we can navigate into device?
Wout Mahieu [SLC] [DevOps Catalyst]12.45K Posted 7th February 2025 1 Comment
Hi Apurva
Configuring what data is shown in the tooltip can be done by adding query columns as a filter to the component. Only the columns that are added will be shown in the tooltip.
Adding an action to execute on click can be configured in the settings of the component. Detailed steps on how to do this can be found in the DataMiner docs.
Miguel Obregon [SLC] [DevOps Catalyst] commented 7th February 2025
There is a nice Kata session about this topic:
Kata 17: Node Edge component: https://www.youtube.com/watch?v=vU2gZQqVEFs
