LCA – LCA taking very long to launch and Error 504 showing up
Solved1.65K views4th June 2024Error504 LCA lowcodeapps
Jon Corral [SLC] [DevOps Member]464 8th March 2024 2 Comments
I am working on a LCA to which I have added some functionalities, that consists on some buttons that launch a UI defined on a IAS. The LCA is taking very long to launch and many times it leads to an error 504, like the one you can see in the following image.
I wonder if this has something to do with the IAS (the AS is only launched when the buttons are run so I understand this is not the case), or if it is something related to the LCA itself. Has anyone seen this before? Is there anything that can be done to solve this?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 4th June 2024
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 12th March 2024
By saying that the app takes a long to load, do you mean the chromium and the components of the app or the data displayed in the app?
Jon Corral [SLC] [DevOps Member] commented 12th March 2024
It is the tables that is taking very long to be populated. Exactly the parts that you can see that appear with a try again button in the screenshot
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 12th March 2024 0 Comments
Hi Jon,
The performance of fetching a table of many different elements has improved drastically in 10.4.3 (docs). Please let us know if you still experience issues on that version.
