LCA – is it possible to change the value of a variable in a LCA from an automation script?
Solved869 views30th June 2025variable
Lucas Sanchez [DevOps Advocate]130 31st March 2025 1 Comment
LCA - How can I change the value of a variable in an LCA from an automation script?
Lucas Sanchez [DevOps Advocate] Selected answer as best 30th June 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 31st March 2025 3 Comments
Hi Lucas,
This feature is expected to be available in the coming months. In the script, you’ll be able to expose output values, which can then be used to set a variable. For now, we’ll only support string variables, as that’s the only type the automation script can currently expose.
What specific use case do you have in mind for this?
Robin Debel [SLC] [DevOps Enabler] Posted new comment 4th July 2025
Lucas Sanchez [DevOps Advocate] commented 1st April 2025
Hi Sebastiaan, string variables will work for the use cases I have in mind. One example is a script that receives three parameters from the low-code app. It will then run some code and should return a string, which we currently show in the console with engine.GenerateInformation. However, it would be better to pass this to a variable in the low-code app to display it in the UI. I understand we could use elements or the DOM for this, but it would be much easier and more efficient to use a simple string variable.
Lucas Sanchez [DevOps Advocate] commented 30th June 2025
Hi Sebastiaan, do you know if this feature is now available? thanks
Robin Debel [SLC] [DevOps Enabler] commented 4th July 2025
Hi Lucas,
Great news! The feature will be available in the 10.5.9 release. A web only upgrade will be sufficient.
Kind regards,
Robin
