LCA : GQI Query – Column reference
Solved1.91K views21st April 2026GQI queries LCA
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.50K 10th March 2025 0 Comments
Dojo,
I have a LCA that has the 'Created by' column of the 'Get services' query selected. When I deploy this app on a another agent this column becomes unchecked with the error below. I repeat this process this time developing the app on a different agent and deploying elsewhere. I get the same the same behavior but with a different column number in the error message.
Does this mean the 'Created by' column has a different column reference on every agent ? This seems odd and makes it impossible to create a generic LCA that can be deployed on any agent.
Perhaps I'm missing something. Any insights will be helpful...
DMA
Web: 10.5.3 (CU0)
Server: 10.5.3.0-15484
API: 10.5.2505.3214
App: 10.5.2505.3214
GQI: No DxM
Klaas Dewitte [SLC] [DevOps Advocate] Answered question 21st April 2026
Klaas Dewitte [SLC] [DevOps Advocate]959 Posted 21st April 2026 0 Comments
From DataMiner web version 10.6.6 (also provided with MR 10.5 CU15 and 10.6 CU3), the alarms, elements, services and views data sources will use the property name instead of it's id as their identifier for the GQI column, which ensures that they can be transferred to other systems.
Existing queries will remain working and will continue targeting the custom properties by id, these columns will be marked with suffix (legacy).
