LCA – error trapped for concatenation
Solved1.79K views24th October 2023
Miloš Sedláček [DevOps Advocate]702 20th October 2023 0 Comments
Hello,
I'm manipulating the columns in my LCA - the goal is to get rid of the "," (comma) in the column UDP PORT. So I'm creating columns PRIOR and AFTER using regexp column manipulation. See the table
As the final step I use the concatenate manipulation method to glue PRIOR and AFTER together to achieve the goal. However, I'm experiencing the "Error trapped: An item with the same key has already been added."
Is it a bug or can I do something better?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 24th October 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 20th October 2023 2 Comments
Hi Miloš,
We can classify this as a software issue, for which we will open a task.
Would it be possible to share your entire query? This will help us in finding out the root cause. Can you also tell us on which DataMiner version you have this exactly?
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Posted new comment 15th January 2024
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 23rd October 2023
Thanks for sharing. We were able to reproduce the issue and we will post an update here once it has been resolved.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 15th January 2024
Update: The issue has been resolved in DataMiner 10.3.0 [CU12] and 10.4.3.
